SX/SXi/SXi Pro Maier Nose Piece 650 SX
JLight
Spanky
Bangor, ME
How should the filler be mounted? I assume it should go under the piece so you can seal it to the top deck. The one I have is used and there are screw holes like the filler was mounted above it. I'm just curious.
StandupWI
Sinking with the bilge on
Milwaukee, WI
I took the filler neck off and then attached between the filler neck and the hull. I also drilled holes at the top near the handle pole and mounted it with the stock hardware. The Maier Nose piece is a lot better then the stock one and have one on each of my 650's.
