I make a new post here about my project to make a jetsurf of a old hull.
I´ve come quite a bit on the way now and start up of the engine is next step.
One of the main thing was to use as many parts as possible from the jetski
and standard parts just to make it easy for other to make it.
The measurements on the hull is not at all wrong length 208cm height 25cm width 62cm and
I have tried my best to keep it as low as possible.
Even the weight I tried to get as low as possible, but the biggest problem is the weight of
the jet pump and the shaft, but I did not want to make a new pump when I saw a lot more that
was has to be solved first and it was nice to have some thing you know works.
The engine is a paraglide engine 2cylinder and boxer type on 170cc and 18Hp at approx 8500rpm
It is aircooled and solved it by make it watercooled by putting copper loops around the cylinders.
It came with ignition and every thing you need to start it including sparkpluggs!
One thing is that the ignition works from 4-8,5 Volts so i hade to put a 5V voltage regulator
Starter engine is from a gras cutter with bendix and seems to work fine.
Fly wheel is from a kawasaki jetski that has been cut off to fitt but no big deal.
Latest from the project exhaust system on place and it was one of the major
problems but it seems to been solved now.
Even if there is pretty much space over when engine is on place it got
harder and harder to find a place for everything.
The whole project from start with picures you find here but only on Swedish sorry
http://jetski-in-sweden.se/forum/viewtopic.php?f=27&t=2180
