jetskiron
Jetskiron
- california
What is the maximum compression I can use for 91 and 93 octane gas, assuming I don't change the timing?
I have a 97 Yamaha Superjet with 701 motor and TNT pipe, etc. I use it for low end work, freestyle riding. I curently have 195 pounds of compression and run 91 octane gas. I'm using a WestCoast head with 650 domes to get the 195 pounds. I want a little more horsepower if possible and I'm considering putting on a different aftermarket head with no domes and just having it milled down to raise the compression to maximum. How difficult is it to change the timing if necessary?
