sfab
X
- Canada, QC
i got a few questions for the knowledgeable guys on this site. ive already built a 61x bigbore and found it has amazing low end punch with nice all around power as well. i like to experiment a bit and was thinking about maximum pistons diameter that can go on a stock 68mm SJ stroke. i know theres already the BB sleeve that can be bore to 86.5mm but i was thinking if it was possible to go with 88mm XP951 seadoo pistons with a seadoo sleeve modified to suit the SJ stroke.
theres a 10mm difference in stroke but im sure the ports can be lowered to match the ones on a 61x. With some transfer ports job (enlarging) could it be possible to run those pistons? im a machinist so i have access to almost any tooling for fabrication. what would be the limitation in that kind of design (im sure theres some...) and how reliable it would be if it was possible to build? since the 61x will offer no support if it was bore to fit those sleeves, they will probably sit in a billet cylinder that will be similar to the 61X with some modifications for the transfers and exhaust ports. i also think that i might have a problem with the wrist pin diameter but i have a few ideas to fix it.
am i just too ignorant or it could be a possible project? :biggthumpup:
thank you!
thank you!
