155 14 vein Maxx pump, 2" set back, long nose prop, and nose cone.
The prop is set up for a 700 to 900cc motor.
The long nose allows different drive shaft lengths. You may need to use a spacer behind your hull seal, so it seals on the drive shaft. If you move your motor forward you will need to use a spacer in the nose of the prop too. It's nice to have the option to reposition your motor for hull balance.
$1200 +shipping and pp fees
Thanks for looking!
Thanks for looking!
