MAXXX Pump Setback Shaft Length
JetManiac
Stoked
Vendor Account
orlando
If it's 2inch set back then 2 inches longer than OEM
It isnt that simple. Setback pumps have the stator hub 'set back' so the shaft is longer from spline tip to impeller stop shelf ,but the rear of a setback shaft is different than in an oem pump. A larger front bearing is used in the front, dand the rear bearing is much closer to the front bearing than in an oem pump. Since the rear is much shorter, the overall shaft length is very similiar to any oem pump.
Also, Bobert your custom shaft is shipping express today.
