- This place called Pacific
Ok so after installing a limiting rope and a hood strap kit from freeride innovations. I've realized that it would be a real PITA to get my paper work out on the water.
So I was a little board today and I kept throwing ideas around of how I could fix this problem. I just so happened to have small watertight pelican case laying around I would use on float trips to keep licenses keys and smokes In. And the light bulb went off. My pole pad I had was doing fine but couldn't I use this pelican case as a pad. So I started playing around to see if it would work.
And it does so here are some pics to show you what I did and maybe some of you guys could do the same.
