Super Jet midshaft rebuild
yamanube
This Is The Way
Staff member
Mandalor
I started a midshaft housing rebuild with an aftermarket kit and found the bearing is about 15mm wide and the original one is about 22mm wide. Will this be an issue?
IS0LD0UT
I hate winter
MN
Learn something new everyday. I thought all the housing that looked the same were the same bearings. Anyone know which are like the SJ and which are like the blaster?
Nube, if you need a SJ style one I probably have one here.
yamanube
This Is The Way
Staff member
Mandalor
The housing is the same, it has a second (I guess third) snap ring groove in it, the only difference between the models is the bearing.
I'm good, got it all assembled and midshaft pressed in.
