Other Mini Extinguisher
DAG
Charlotte, NC
For those looking for a Small extinguisher, perhaps take a gander at these at $5 each with free shipping, hard to pass up even if they don't hold up well.
I have used a few mini's in the past and around here the local lake wildlife ok's them. These are not USCG approved, so if the local wildlife knew what to look for, they would be illegal. (might be able to play dumb and get off with a warning). These do have the AB labels on them.
The problem with the mini's I've used in the past they just don't hold up well in salt or have paper labels that bleed though. This one is the smallest yet, not sure on the weight as this is foamer. I'm going to take the plunge, if they don't pan out the worst case scenario I'll have something to squeeze off onto the neighborhood hoodlums'.
http://www.ebay.com/itm/2-Nitro-Str...s-/390489361489?forcev4exp=true&forceRpt=true
WFO Speedracer
Alabama
Small enough to fit in your jet ski , more powerful than drunk guys pissing on a fire, able to piss off any Marine patrol officer in a nearby radius , its Max professional mini foamer to the rescue !
how's that ?
Tyrant1919
Washington, DC
The extinguisher I have is the smallest 'real' extuinguisher I've seen. Not just a can of air with some water and bubble soap in it. Not CG approved though. I never take it out since it's a !$!$%$# to put back in. It's a little longer than a 16.9 fl oz bottle of water, same thickness. I'll run this forever. It looks exactly like one you would see sitting inside one of those "Break in case of fire" windows in an office building or your appt complex, just way small. It's got the legit pull pin and everything. I wouldn't run with one of those extuinguishers in a can. CG would laugh at me. I need to get a good picture of it for you guys. Tomorrow maybe.
kraqus
Where did you get it? Link?
Benny
Tyrant1919
Washington, DC
Get em! $32
http://www.trianglefireinc.com/Amer...-p/a620t.htm?gclid=CJahhPDPr7MCFSFyQgodsCgA6A
nice chrome looking one on ebay :^)
http://www.ebay.com/itm/1-lb-CHROME..._Security_Fire_Protection&hash=item3a771e39a5
From their product catalog pg11: http://amerex-fire.com/wp-content/uploads/2012/07/Product-Catalog11.pdf
Size & Capacity (lbs.): 1
Model Number: A620T
U/L & ULC Rating: 2B:C
Height: 10 inches
Width: 3 1/2 inches
Depth: 2 3/4 Diameter inches
Range: 5 - 8 ft
Discharge Time: 10 seconds
Standard Bracket: Vehicle
And the most important thing: >>>USCG Approved with Bracket Listed on UL Label<<<
kraqus
Oh Man! FINALLY one that actually complies and it is actually small enough to carry. Thanks for the link!
Benny
