- Minneapolis, Minnesota
I figured I would document my build here for others entertainment and getting any help I need along the way. Maybe others can learn from a few things I pick up along the way and ensure you realize all the parts you'll need and details of a build. At first I was planning on ripping apart my 06 Superjet, but ended up going off the deep end and buying new stuff so the Superjet stays unaltered.
Taylor from TC Freeride really set me up well and delivered.
Erik and Todd at TPE will be supplying the motor and goodies, but probably a 4 week wait. This will be my limiting component.
Jetmaniac hooked me up with tons of equipment, and lightning fast. It's really astonishing how fast the first box arrived.
Parts list:
2016 Rickter XFR - Fiberglass - Yellow - Trash (No front foothold. Not sure if that is an option but it showed it in the video and I had no idea if I was getting it or not. I would have liked it.)
RRP Billet Lightweight Pole, Black tubes, Black end pieces with black/yellow RRP chinpad
RRP 155mm Trim
RRP Straight bars
ODI Grips
RRP Throttle lever
RRP Intake Grate
RRP 155mm pump shoe
RRP medium ride plate
Drivetrain:
TPE 1105, ADR crankshaft
TNT V3 Pipe and waterbox
TNT Exhaust hardware kit with flow control valve
Dasa 48mm carbs (includes throttle wheel and connection kit)
PHP Intake manifold
Vforce 3 reeds
Superjet engine mounts, bedplates, OEM bolts, washers and shim kit
Skat Trak 155mm Setback Mag pump with a cutback 9/16 impeller - JetManiac
155 mm Pump shoe seal
Pump shim kit
Misc:
OEM Midshaft with OEM 5 finger couplers+dampener - JetManiac
Exhaust tube, 3 feet
Flywheel cover, black, with hardware
10 ft OEM Fuel line
Tau Ceti 2" filters, 2X
Cold Fusion E box mount + bolts to mount
Cold Fusion hood prongs (mounts are included on the hull side, not the hood)
RRP spacer for billet poles (going without a spring)
Shorter pump to hull bolts for pump x4
Bilge pump and outlet hose
2 ADA bypass fittings 45 degree
2 ADA bilge outlet fittings 45 degree
OEM Parts
Start/stop switch with lanyard
Steering cable parts (pre 08 cable, extension, 08+ Joint Ball stud, plus others below)
Hood latch
Midshaft cover
Flywheel key
Under the flywheel cover parts (Bendix flycover spring and f/r washers, stator bolts, flywheel bolt)
Motor mount bolt kit
Pole bolt (stainless), washer, and nut
Midshaft bolt kit
Hold downs for straps for exhaust, fuel tank, battery + bolts to hull
Rubber Straps
Intake grate bolts+washers
Electrical:
OEM Ebox with MSD Enhancer
Lightweight 62T flywheel and OEM 62T stator
OEM Bendix
OEM Starter
Deka ETX12 battery
Fuel:
Limited Slip 3.3 gallon tank with battery mount, Anodized black
2 Puralator Fuel filters
Consumables:
3M 5200 Adhesive - black
Anti seize lubricant
Locktite Blue and Red
Handy tools:
Metric allen socket set
Spline holder tool by Solas
Drill bits/taps
This will be updated as I go along. A spreadsheet will eventually be attached too. PM if you want me to send it to you before its final.
What was included with the hull: Ride plate bolts!
Picked up the hull today and took a few pictures. I'll be posting a bunch of pictures, watch out.
Parts list:
RRP 155mm Trim
RRP Straight bars
ODI Grips
RRP Throttle lever
RRP Intake Grate
RRP 155mm pump shoe
Drivetrain:
PHP Intake manifold
Vforce 3 reeds
Pump shim kit
Misc:
10 ft OEM Fuel line
OEM Parts
Hood latch
Midshaft cover
Flywheel key
Midshaft bolt kit
Rubber Straps
Electrical:
OEM Bendix
OEM Starter
Deka ETX12 battery
Fuel:
Consumables:
Handy tools:
Drill bits/taps
