moisture inside flywheel
Anybody ever run across a stuck bendix and it seems like a little water or moisture got inside whats the trick seal is new just shooting for idea. Should I put some marine grease along bottom on the seal the fly wheel doesn't have block off its a 701 2005 motor
Stockton
I grease both sides of the FW gasket and behind the stator wire grommet. You can also use silicone. 2nd, put a Silicone beed on starter nose, so when starter is reinstalled it acts like secondary seal to your starter nose seals.
Quinc
Buy a Superjet
California
You can take apart the bendix pretty easy and clean it up with some wd and a wirebrush. There is a thread on here somewhere.
hhh
When mine did that it wasn't a leak but humidity that caused a little moisture inside. Where I live the humidity is very high in the summer.
FlightPlanDan
Don'tTrustAfartAfter50
Yamabond or something similar can't hurt when sealing the flywheel cover.
Although the starters are "O-ring sealed", I've always used 5200 as an extra between metal surfaces. This means pulling the motor to do it properly, but it's worked for me so far.
