- Arnold MO.
Im running prok filters with blowsion prefilters. Every time the ski goes under it sucks water into the carbs. and ideas? I put weather strip around the hull where the hood seal meets it and blocked off the openings on the sides but still no luck. I also have about a 7" drop tube on the rear opening and a 3" (stock) drop tube on the front opening so water goes in front of the pipe. I was going to switch to a factory air box if I can find one but noticed most people use A.M. filters. Surely I'm not the only one dealing with water ingestion.
