Motor Mount Stopper 701
Req
SW Tenn
If memory serves there is not enough room on the stand ups to run it. I tried on my superjet and never could reach the mounts, I had to remove it. I think most people just torque the bolts in without the stopper.
Quinc
Buy a Superjet
California
You might have the longer one meant for the b1 or waveraider. You can either cut it to fit your hull or not run it.
  • Like
Reactions: Req
Req
SW Tenn
It was out of a raider so that explains it! Back to his question, how important is it? Does it help with blown out mounts or midshaft housings?
Quinc
Buy a Superjet
California
Vibration? All of the above? Run it if you got it, dont worry about it if you don't?
  • Like
Reactions: Req
I was thinking it would be like a 5th engine mount to help the motor from sliding forward or backwards ? ... maybe less stress...or help with vibration I know all couches have them
LOTO
One came on our 08 SJ and we still run it. I like the idea of running one, set up right I would think it could only help support the engine in any hull, stock or am.
Stockton
On some after market hulls the bottom of engine is close to the hull, and/or, Sometimes when you flat land or flat land with a bad mount the case bolts can go thru the hull. Like Qunic said, you can trim it to fit your hull. Might be too tall like req mentioned
