Mount up freeriders!
JetManiac offers you lots of choices for motor mounts.
SuperJet motor mounts
(fit all years 1990-2020 SuperJet and most aftermarket standup hulls)
Yamaha OEM new SuperJet mounts $97.99/ea Sale 75.90/ea
Rhaas new urethane billet SuperJet motor mounts $49.95/ea.
These mounts offer anodized billet bases and a new formula urethane. The urethane is not just bonded to the base, they are co-molded to the base with a mechanical lock.
2 year breakage warranty from Rhaas products as well.
Yamaha OEM new 'couch' mounts $97.99/ea Sale 75.90/ea
Yamaha OEM 'couch' clean used freshwater mounts 32.95/ea.
They are not just for couches anymore!
SuperJet 'Alternative' Motor Mounts. Many freeriders (including the Maniac) are using motor mounts from a Yami couch in their SuperJets or Aftermarket standup hulls. SuperJet mounts were designed for the 650 motor, but these GP style mounts are beefier with larger rubber and more metal to rubber surface area for strong shear strength. Proven strong in the surf for years.
These will fit a SN or RN SuperJet and have the same angle, but they are a little taller. Adjust them outward in the hull before tightening and use less or no shims. Alignment in some hulls require slotting the holes inward or belt sanding the bottoms.
(must clearance kenny keepers to fit them)
http://www.x-h2o.com/threads/74378-Superjet-Alternative-Motor-Mounts-15.&highlight=couch mounts
Monkey Grip SuperJet motor mounts 42.95/ea. sale 41./ea.
RRP Billet Motor Mount - Superjet / Rickter
RRP Adjustable Billet Motor Mounts. Fits all years Yamaha Superjet and Rickter Models.
Available in Black, Blue, Red and Green.
RRP Adjustable Billet Motor Mounts 75.79/ea
Cold Fusion new billet motor mounts -these were discontinued by Cold Fusion and are no longer available.
Motor Mount SS OEM Hardware and Shims
OEM motor mount bolt kit 28.90
(8 motor mount to hull bolts, 4 motor mount to engine bolts/large washers- clean, used oem hardware)
Motor stainless shims kit (8 pack) 25.95
(Or 3.50/ea. 2mm, 1.0mm, or 0.5mm thicknesses)
Pump stainless shims kit (8 pack) 20.95
Rhass motor mount lock washers 5.95/ea
Pump bolt to hull tray brass OEM threaded tray insert 4.75
Blaster and FX-1 Motor Mounts
Yamaha OEM new Waveblaster/FX1 motor mounts $97.99/ea Sale 76.90/ea
Rhaas urethane Blaster motor mounts 49.95/ea
(2 year warranty)
Monkey Grip Blaster or FX1 motor mounts $47. sale 42.89/ea
These mounts fit:
1993-1996 Yamaha WaveBlaster 1 701
1996-1997 Yamaha WaveBlaster 2 760
1994-1995 Yamaha FX-1 701
(2 year warranty)
These mounts fit:
