Motor setup debate
650sx mod
Grand Rapids MI
Michigan
Hi i have a 62t 701 motor im going to running vforce reeds dasa manifold duel carbs msd enhancer mas coil the motor is bored .5 over with stock head my plan is eventually to put a head on it and a lighter flywheel but right now im running a 650 yamaha flywheel and stator and stock head i want to know how i have it setup how snappy and good it will be say compared to a 701 61x as all i really want is low end for tricks. If you could give me some input I would greatly appreciate it thanks.
Thanks what should i run for jetting on my motor running dual 48s
you are going to lose bottom end snap running 48mm carbs. huge carbs on a small motor give it high RPMs not low end snap. dual 38s or maybe 44s but not 48s. I've ran many a 48s on 701s and they were top end faster than anything else but bottom end was softer
A b pipe, 180+psi, enhancer, 9/15 or similar prop and stock 38s will work for you. That is a tried and true combo x10. Add Porting to the cyl and case for even more snap.
