Here is the description from ebay.
This is the more desirable dual carb motor found on RoundNose Yamaha Superjets, Waveblasters, WaveVentures, WaveRaiders, and more. This motor was just pulled from a great running superjet, and as you can see in my photos below, it has strong compression at approximately 160lbs per cylinder.
This motor was originally out of a WaveVenture so it has 62t Cases and 62t Cylinder, thus I am including the exhaust manifold bolts so that way you will have everything you need in case you are replacing a 61x motor (the 62t bolts use a larger/stronger thread on the exhaust bolts as opposed to the 61x.)
I went through the motor in August and installed a new top end with WSM Platinum Pistons/Bearings/Pins/Clips as well as new base and head gaskets. There are approximately 10hrs on the motor since the rebuild. It runs strong and it is ready to drop in almost any older Yamaha Ski. Upgrade that 650 or single carb 701 to a nice dual carb 62t!!!!
You will be getting the assembled shortblock plus bedplates, flywheel cover, engine coupler, and a starter motor. Electrical, stator, flywheel, carbs, etc.. are NOT included
