300 hull is identical to 440/550 JS
the 300 SX on the other hand is a MUCH different n smaller hull.
with the standard 300 hull you can bolt a 440/550/550sx motor right in with not custom modifications needed besides supporting mods.
the 300/300sx/440 all share the same pump...the 550 n 550sx are NOT the same.
If you wont the most power will keeping it super easy as far as swap goes....then look for a 550sx motor
