superjetguy
It's hard to speak without a tongue.
- lake hogan
Hey guys, I'm running into multiple issues and I'm now regretting not getting your insight before I purchased parts.. A while ago I bought some jetworks TT modded 38s everything was fine with those on my 62t cases. I have a new build now and I'm suuuuper low on fundage, anyways it's a Xft and it has a 61x/61x. It had a single 44 on it, I figured I'd use those my 38mm jetworks carbs on it so I bought a new protec intake manifold for dual 38s. First issue, the bottom of the carbs where the adapters for the 62t mounting is threaded. Can I drill these out to slide over the studs on the manifold? And the second issue, even if I drill those out to fit over the bolts the spacing between the carbs is to far apart, about 15mm, to slide over the studs. Is there new linkage I have to buy or some way I can make it work?
