- miami, fl
i have a single trailer that i pull my sxr with and i want to mount a trailer box for my straps, oil, possibly securty chains, etc.
it has enough tongue space for a tool box and the trailer is rated for 1200#.
any ideas, or pics on how i should mount it to a single beam tongue?
i was just going to make a base for the tool box to sit on (3/4" plywood) cut into the same shape of the box bottom then U-bolt the plywood to the trailer tongue and either screw down the box to the wood
HomeDepot sells aluminum stock (L-shaped, boxed, etc.) maybe make a base with that and then plywood?
