- vancouver wa
anyone able to repair an MSD 701 enhancer? I have lost spark with it and swapped with a stocker for now.
Interesting, ill have to look into that! would be nice to save $500 on a new one lolrumor has it you can bake it in the oven. There is a thread on here somewhere about it. But I have never tried it.
I am thinking that was on the total loss modules.rumor has it you can bake it in the oven. There is a thread on here somewhere about it. But I have never tried it.
96 superjet 62t/62t b pipe, girdled head, v force reeds, stock carbs, flywheel, stator, coil and e box.What's your motor/hull setup?
Pick up a modded stock cdi. There's a guy that mods them to 8100 rpm. Can be had for 100$ or less, or find a protec modded one.96 superjet 62t/62t b pipe, girdled head, v force reeds, stock carbs, flywheel, stator, coil and e box.
Yeah I’ll have to check those out! Thank you for the advicePick up a modded stock cdi. There's a guy that mods them to 8100 rpm. Can be had for 100$ or less, or find a protec modded one.
If you are really after all the throttle response possible, a zeeltronic setup is the ticket(programmable) but that's expensive like an enhancer.
Or you can mod your own, It's pretty easy. https://www.x-h2o.com/threads/superjet-cdi-modification.496/Yeah I’ll have to check those out! Thank you for the advice
