MSD Enhancer - what is the rev-limiter range?
T-bone
brraap....thats so 2002
never have found out what the range was, so i just run it all the way out and try not to rev it when it leaves the water.
keefer
T1
Tennessee
I think it 8000 or 8500 not for sure. Either way it plenty high and will give plenty of overrev if you run it all the way out or just back off a little from full turn on the adjuster.
I realize I could crank it up and run 8K or 9K (or maxed)...but I rather only keep my limiter 500rpm (or so) above my in the water limit. I do lots of open ocean WOT and need a safety margin.
Someone must know the actual answer :dunno:
(If no one steps up I'll call MSD next week)
heres what the paperwork says that comes with the enhancer:
"the adjustable rev limiting function of the enhancer ignition is pre-set at the factory at 8,000 rpm. its adjustable range is from 5,500 - 9,000 rpm. with this in mind, every 1/3 turn is approximately 1,100 rpm."
Ahh haaa! That is the exact info I was looking for :Banane01:
Thanx for diggin' that up.
