Other Msd t/l pro series II spark only on front cylinder? Help please
I purchases a wave blaster that has an msd t/l pro series II system. I test fired it before I bought it, checked spark and compression all was fine. Now a day later I tried to start it and only the front cylinder has spark. Need some help with what to look for as I e never worked with a total loss system before.
Knoxie
www.kp-parts.com
New Zealand
if its a single channel TL system and producing a normal spark on at least one cylinder, then the problem will most likely be in your coil , spark plug lead(s), or the spark plug(s)
Ok. Yes One cylinder has good strong spark. The other has nothing. I switched the plug wires at the coil and that wire and plug fired nice and bright as well. So where can I buy a coil for this system? Also how can I tell if its a single channel system?
Knoxie
www.kp-parts.com
New Zealand
those old pro-series 2 are single channel, a multi channel system uses an individual pick-up and individual single tower coil for each cylinder. On a single channel system you can just use the normal stock standard coil if you wish,
