Soo have some problems with my TL, it started too run bad got worse and finaly ski Will not starte. Pullede out off the ski did a bench and it was good, 1 ignition wire hade come loose from the spark plug clamp. Fixede both ignition wires and mountede everything too a xs total loss plate, puth it back in the ski and now it cranks but only sparks a couple off times (both plugs) then stoppes even if cranking countinues. Took off the SS swith stop button did not make a diffrens, put a stock 61x ignition inn and it fired right up. Soo i am att a loss where too goe from here
Extra info
Battery is 20ah and hade 12,7 volts on it doing cranking
Coils was never discornected from brain
Led is blinking after first start up attempt
Have 4 grund wires on it all new
Any idears ??????
Extra info
Any idears ??????
