MSD TL Trigger/Pick-up Question?
YAMA CAT
Catnip Junkie!
B'ham, AL
Whats the difference between 4316 and 43161? Both of these trigger work with the 2530 / 42351 Dual Digital Brain. Does the 43161 come with more shims? All the pictures I have seen they look the same. Will a 43161 fit in a 61x/62t setup?
I asked this question @ the MSD site and so far no replies.
YAMA CAT
Catnip Junkie!
B'ham, AL
The 43161 triggers are used on the 800/1100 Yamahas and 4316 and used on the 701/760 Yamahas, Kawasaki, and Sea doo. What's odd to me in one of the parts lists for a Universal Kit it shows 43161 triggers.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
I don't know any of the part #'s but have a TL on the shelf and can look at the package if needed, But I do know the the difference in in the Yamaha 701 is a plain drilled hole for mounting and the thread insert is in the backing plate, on like 1200R/800 setup the threaded insert is in the trigger plate and a plain hole in the backing plate.
If you get the ones for the 1200/800 you can just use a small punch and drive them out then slightly run a cleanup drill through and will be exactly like the ones for the 701.
