So i am having some issue with my Msd TL the past couple weekends. Originally it seemed like the ski was dying every time I landed from a flip or spin. Even soft landings from a small 180 would stall the motor.
Based on some FB feedback I found the “shifty mod” bad. I could start motor. Tap relay and ski would die. Bought a new “shifty mod” and installed. This morning ski started ran good. Tapped relay a few times no issue.
First tank out todsy ski seemed to be fine. Second tank it stated dying again, even stalled on a prehop. After doing some investigating I have noticed I fire ski and red light on msd is on as normal. If i rev motor over about 3/4 throttle light goes out and ski dies. A slight bump of start button while motor is still rotating and light comes back on and it will idle. Any advise is highly appreciated.
