customride0105
- sterling va
msd total loss set up.
Msd totall loss kit (1450)
Brain has 2 rides on it.
Kawi style starter relay
Wired into a rad dudes vault (425)
Riva adjustable flywheel cover (400)
Rad flywheel .key way has no damage ring gear has normal wear and tear
No need to remove the flywheel cover or flywheel to adjust the timing do it all with the flywheel cover on.
Wired up for oem superjet style start stop.
Set up is better than new. And water wont get in. Simple plug and play with this set up
Note I did grind the one ear to have it fit in a ski. And I did loose one of the screws for the cover .
You will be hard pressed to find a better set up out there.
This is a fresh water set up.
Asking 1000 obo
Asking 1000 obo
