MSD vs KV coil
Please help, I have a Kawi 550 with a PJS Reed motor total loss MSD ignition , I think the coil died, as I have no spark, did the pickup coil check as per MSD. I ohm checked the coil, 11.3 plug to plug.and 3.4 on connecting wire sides. Anyone know what they should be?
I have a KV coil, will that work with the MSD system?
Thanks for any input
yes but sometimes the cables are too corroded to let current through so that's the reason we cut them back to fresh conductor.
