Freestyle My 300sx build
Michigan
I picked this 300sx Hull up last Friday and here it goes 1 week later. In the end I hope to have a zxi750 motor in it.Picture 011.jpgPicture 012.jpgPicture 015.jpgstarted sanding it.Picture 027.jpgPicture 028.jpgThe top is sanded now to the footholds.Picture 031.jpgPicture 033.jpgPicture 035.jpgPicture 042.jpgPicture 044.jpg
Michigan
I picked up a downer 750ss for the motor and pump and a superjet handle pole for it. Ill have some Pics of the Progress this weekend. Thanks for checkin it out.
Fro Diesel
creative control
Kzoo
Awesome start on the project, Im doing the same but with a 440 hull. Hey where did you find the foam rails to re-shape and cut in your foot holds? I would love to get my hands on some!!
Looks like 1 inch polystyrne can be had at most hardware stores.
Nice work on the footholds!
Sent from Fro Diesel using Tapatalk
Michigan
Ok got a lot more done. I got the pump, shaft and motor placed and the handle pole all ready. Here is the pics so far. Picture 060.jpgPicture 073.jpgPicture 072.jpgPicture 080.jpgPicture 081.jpgPicture 085.jpgPicture 086.jpgPicture 105.jpgPicture 106.jpg Now I have to fiberglass everything in place and get started on shaping the front.
looks awesome. I can't wait to start something like this. Every 300sx build has someone 5 posts down who comments about picking up 15 300sx's for $5, meanwhile only one has come up around 50 miles from me and it was for 450 dollars. And being advertised as a kawasaki js400
Michigan
Here is some more pics of what I have done so far. This is what Im thinking I want it to look like in the end Picture 109.jpgMotor mounts in place.Picture 114.jpgPicture 118.jpg Foot holds glassed and the front foothold is shapedPicture 117.jpgPicture 121.jpgPicture 130.jpgPicture 124.jpgPicture 126.jpg
tokarzl
itching my arms
Thanks guys. I got a question tho. The cooling line going through the hull is broke what is the line made of and what can I replace it with?
Stainless Steel Tubing!! If you have a pipe supplier near you they should have something for you. 3/8" Dia. for cooling 1/2" Dia. for trim tube, I would run for dual cooling and trim while your in there.
