650/X-2 n00b 650sx questions
Hepper
n00b
South Dakota
Im tearing apart my 650sx and i disconnected everything from the engine and pulled it out only to find that there is no easy way to disconnect the wiring running from the box to the engine. Then I figured I pop the box out and just pull all the wiring out still connected to the engine, so i start disassembling the handle pole so i can pull the start/kill switch out and lift my engine and electronics. Thats where I ran into my second snag. Is there an easy way to pull all the wiring through the handle pole? I assumed it would be mostly just a hollow shell and I could just disconnect everything from the bars and yank it out but there are holes only big enough to get the wiring through, not the start/kill switch. So basically:
1. How do I disconnect the wiring from the engine?
2. How can i pull the wiring out of the handle pole?
It's much easier to just open the actual e-box. All the wires if still in a factory set-up should have quick connects.
What is your ultimate goal you want to do with all this? Maybe you do need to pull the wires off the bar... but if your just trying to get the engine free disconnecting it from the e-box is much easier.
Hepper
n00b
South Dakota
got everything pulled apart... the problem i had with pulling out all the wiring and stearing/throttle cables from the handlepole was that the damn vent hose from the gas tank was wrapped around everything so it made it hard to pull the :):):):) through.
