Custom/Hybrid near perfect engine to mid-shaft align jig' setup
SuperDrifter
Prototyper
Floridapunk
If you are relocating a bulkhead....3mm star plate/3" T clamp/ 2" C clamps
1.
- setup jig
- assemble bulkhead to assembly
- drop engine
- glass bulkhead
- remove engine/mid-shaft
- Bulkhead/Mid-shaft/ engine are aligned
2. Next step
- install mid-shaft
- back pump spline out 3/16"
- mark pump PXL_20240719_020829114.jpglength location
- install mid-shaft alignment tool
- more body mods for 160mm pump in a 122mm hull.
