Super Jet Necessary tools?
Midlake Crisis
Bakersfield, CA
stubby 1/4" ratchet with extensions
torque wrench
sockets with extra 10mm, 12mm sockets
modded end wrench for b-pipe manifold
end wrench for b-pipe water screw nuts
Really long handle bent needle nosed pliers
Spark plug wrench or socket
Specific screwdriver bits kept set apart to make life easy:
- big fat phillips (i.e. eBox)
- tiny phillips (i.e. carb internals)
- small, med, large flat (carb jets, carb plates)
flywheel puller
impeller wrench
2' ski rope / piston stop
spark plug tester
multi-meter
wire stripper
crimper & heat shrink wire terminals, butt connectors
dielectric grease
loc tite (blue & red)
SXIPro
JM781 Big Bore
Crowfoot wrenches for getting at the damn carb nuts.
Breaker bar
Cooler of beer
Leakdown tester
Compression gauge
Cooler of beer
zip ties
2 part marine epoxy
heat gun
PB Blaster
Cooler of beer
Vise
Torch
Rubber Mallet
Cooler of beer
there isnt many tools you need to do most of the basics on a superjet...
ofcoarse some tools are going to make life alot easier and quicker most can be done with the regulars.
get yourself a decent socket/ratchet set with both 1/4 and 3/8 drive.
a long 3/8 extension and a long long flat blade screw driver makes alot of things very very easy.
assortment of screw drivers and pliers.
volt meter.
rubber malet.
multi end spanners (wrenches).
compression gauge.
duct tape and thread lock.
