Thanks Poor Boy Racing. I have to check tomorrow what pitches the Solas Dynafly impellers come in. I was looking at the pump cones wasn't sure if it was a gimmick item or it actually worked. I will have to order one of those as well. Last item I was looking at was the Jet Dynamics aluminum pump shoe it that a worthwhile investment? I also seen R & D have these little spacers that goes into the stock pump shoe to lessen cavitation. Have you tried either of those?
Thanks
Are you going full race limited, like
@vomitspot 's setup? (Dry Pipe, Drop domes, on race fuel, etc) or considering a wet pipe, pump gas, etc? Makes a difference on how you tune your pump. I would figure out how and what my setup was going to be before I started on the pump.
@user_error is right about what works on the pump and the fact that you will probably end up re-pitching any dynafly you buy.
I ran a Solas 140mm pump on my last SXR (wet pipe, 175 psi, pump gas, Advent T3, TBM Charging wheel, Novi modded carbs) and the sweet spot on my Dynafly ended up being at 13/21. The Solas pump worked good, but I couldn't tell much improvement over my stock pump with a TBM stuffer.
