Custom/Hybrid need diy repitch
Just like the title says would like some good info on how to repitch a prop. I don't want tosend it to impro's. I've heard they take for ever. I've gotta 7/18 and I need more low end.
DAG
Charlotte, NC
There is a ton of info over on greehulk. There is a guy that even had a DIY hitch mount prop bender so you can test and tune at the lake. There is also a .pdf floating around that you can print out yourself, however, it's not useable b/c of how it's formatted on 8.5x11, I couldn't get it to come out correctly on 11x17. Ended up makeing some on heavy gauge 22" translucent Mylar. I have a few extra if anyone wants them. Asking $10 and ship/pp. PM for details, not trying to derail the thread just listing options. image.jpgimage.jpg
Vumad
Super Hero, with a cape!
St. Pete, FL
There is a ton of info over on greehulk. There is a guy that even had a DIY hitch mount prop bender so you can test and tune at the lake. There is also a .pdf floating around that you can print out yourself, however, it's not useable b/c of how it's formatted on 8.5x11, I couldn't get it to come out correctly on 11x17. Ended up makeing some on heavy gauge 22" translucent Mylar. I have a few extra if anyone wants them. Asking $10 and ship/pp. PM for details, not trying to derail the thread just listing options. View attachment 247175View attachment 247176
Wish I had put a sxr pump on my x2. Lakeside repitched would be awesome!
Just so you don't mess up your prop just know that the trailing edge is 1000 times easier to repitch than the leading edge. And according to most the leading edge has a greater impact on bottom end. Trailing edge is more top speed.
  • Like
Reactions: DAG
DAG
Charlotte, NC
Not being sarcastic, my trade is in metal forming. (not props thou). Bending the prop "work hardens" the piece up until it reaches its yield point. At which point the material become ductile, necks, then fails. With that being said its not the number of times a prop is repitched its how far its away from nominal, and the process the prop went thru to get there. If the prop was only bent 1 direction 15' at a time I bet you could repitch it a dozen times. for a bad example
hhh
Work hardening is a butch when you loose a 500 tool in a 3000 detail. But the terms weak, fatigued, and soften are often used to describe it. Nice post dag
Do you work with roll forming or brake?
dfw
Most available impellers are too steep for what we do and most people tend to go up rather than down when they buy one. Nearly all modern units (except Dynaflys) are cambered and have a low leading edge angle. Raising the trailing edge will unload the pump without hurting anything. Large hubs are more difficult to work than small hubs so you need to select them more carefully to begin with. The problem with Greenhulks method is our props dont have enough room for a big cresent to go lower in pitch. Maybe a modified Ford or monkey wrench but who has one of those anymore. I chuck the hub (top to bottom) in a soft aluminum jaw vise and work the blades with an aluminum stick and 2lb hammer. It takes some practice but you can find huge gains from small 701-760 engines. Larger low port and PV engines can usually pull the steeper props.
