- Ontario, Canada
Click bate title, thanks for looking.
How are you getting the front end of your blasters up? My 2010 sj had static trim that I had maxed out from day 1. Being a lighter rider comes with pro's and cons. If i'm riding with more than 3/4 tank of fuel i'm pushing water unless i'm into the throttle at least a little. This normal on a b1? I also "plow" through waves rather than ramping up them like I could on my sj. Plan so far is to D cut the ride plate and throw on slightly taller TAG bars that I already had from my mx parts bin. Has anyone installed a static trim setup on one of these things with any good result?
Cheers
Cheers
