Hey,
Last season this top end blew due to my rookie mistake of not putting the C clip in correct (i believe). I am now trying to identify the sleeves to replace and rebuild it. The sleeves have a 90mm (+/- .05mm) outside diameter, and a 142.3mm (+/- .03mm) height. The were bored at 84.45mm. they are a 5 port plus exhaust sleeve. The bottom of the exhaust port to the bottom of the skirt is 68.3mm. my cylinder base to head surface height is 118.5mm. These are in 61x y-3 cylinders.
Can anyone give me an idea on what sleeve I have here and a suggestion on a replacement?
Thanks!
Thanks!
