- Kennesaw GA
I have a stock 95 sn with a 61x 701 and stock 44mm carb.
I added a limited b-pipe, factory waterbox and ocean pro spark arrestor.
I now have no bottom end but the mid and top end scream, does anyone have a similar setup and what are your carb settings?
Right now mine is set to FFP suggestions.
Main Jet : 145
Pilot Jet : 120
High speed screw : 12 turns out from closed
Low speed screw : 2 2 turns out from closed
Needle & Seat : Stock
Spring : 95 gram
Main Jet : 145
Pilot Jet : 120
Spring : 95 gram
