extreemthrottle
freeride junkie
- north palm beach
o.k. i realize this has been posted before, but i've gone threw all of the listings and took the time to try all the suggestions.
what i have is a 61x bottom end and a 64x topend, in my blaster 1. single carb setup, greater head, with 40cc domes running approx 165 psi in each hole. factory b pipe with a stainless limited chamber with dual cooling. i ran this same setup on my original stock 61x motor before with no issues.
i've gone threw the pipe two or three times to make sure i have'nt missed anything, pulled out the adjusting screws, ran a welding tip cleaner through the holes until they were clean, blew out everything with compressed air . i've double and triple checked the plumbing, in and out of the pipe. i have turned the bottom screw out over one turn and the top screw out more than one turn, but still the chamber is sizzling way too much. the motor seems to be running at a good temp but the chamber will not cool down enough. i have it to where the first part of the chamber (closes to the head pipe) is the only part that really sizzles, the rest is barely sizzling.
could it be the head is not moving enough water the the head pipe? its the only difference from the stock motor other than the larger displacement.
i'm getting very frustrated with the whole thing and watching as summer is coming to an end without a resolution in sight.. really don't know where to go from here, so any suggestions would be greatly appreciated..
