Need help with Havoc
Intake grate not matching up to shoe. Bought ski without grate installed. Im guessing its the wrong shoe? I have the +2 JD grate and the front lines up. 2015 Havoc full carbon hull. Help please and if you can get me part #s, if I need to order, that would be great. Thanks.
Jr.
Standing Tall
Staff member
Hot-Lanta
Hard to clearly tell from the photos, but the shoe is correct, you will just need to drill and tap mounting holes.
The grate is to long? You will need a std length grate? Maybe someone with a Havoc will chime in on if thats what these hulls take?
Aftermarket in the jet ski world means modifications required. Cut, grind, weld, slot, epoxy, build up, trim, drill, tap, chamfer, etc. In other words, you need to make stuff fit.
hornedogg79
dodgin' bass boats
Yeah I went through this. Jet dynamics is terrible. At least it's the most expensive intake on the market! Ha. They should send a 40grit flap wheel with each purchase. It doesn't even match their own pump shoe. You have to grind grind grind until it sits flush.
I second that, was probably the most painful part of my last build. Was a real mess. This was what all I cut off of mine to make it fit.
Length is correct. They take a +2. Rear fit sucks.
