300/440/550 Need input!!!!!
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
Anything will work that will be aftermarket: long plate with fins will make you turn much bateer and will add stability. Also a grate with wing will keep that pump loaded. Or if you ride calm water an open one. Buy 2. Change them accrodingly to conditions - the best option.
650's were notorious for poor handling characteristics, get yourself a toploading intake grate and a extended rideplate, and a good impeller. After that you can experiment with handle bars quick steer and so on. Beyond that its all you.
