Need serious help with msd connections
Can someone tell me why barely any of these colors match up on my ebox, thank you
//images.tapatalk-cdn.com/15/11/23/a713aaaed78585f7ac96483037772120.jpg[/IMG
[IMG]//images.tapatalk-cdn.com/15/11/23/9356041252786d83a88144e6cf4e311f.jpg
eastcoastjumper
James
Long Island
OCD Solutions
Rentz, GA
- Brown to brown is pretty straight forward if you ignore the white stripe.
- The pink goes to a head temp sensor that you may or may not still have installed.
- The white needs the jumper with a female plug on each end to convert the gender. The Enhancer was designed for the 61X but can work on a 62T if you use the supplied jumper.
Did I miss anything else?
