- Brighton, MI
Hello, I'm new here, and new to jet skis. I was given this 1990 superjet a year or so ago, and it was all in pieces, with a blown engine. I have been slowly putting it back together. I put a 701 engine in it. Now I'm trying to figure out how to hook the cooling lines back up. There are these two cooling lines on the back of the hull pictured here....
Heres the two lines in question, I'm assuming the bilge pump hooks up to the line on the left side of the ski, and the rubber hose to the other one, but then where does that rubber hose go?
Sorry if this is confusing, maybe someone has some good pictures of their stock SJ 650, I can take a look at to figure out the routing of these cooling lines?
Also I have a question about the Bendix gear, it gets stuck in the "out" position, and it will not go back down unless I tap it on the work bench, so I'm assuming its shot?
