Need Some Jetting Help for 850 BB
Shonuff
I've got the glow
Memphis
Just got my BB 850 back from Group K but have a mild bog on the low end that I can't seem to tune out.
Do I rejet? and do I rejet larger?
Cross
X
WA
Your are too lean. I would say try 80 low, 150 high, 95 gr spring, 2.0 needle and seat. The stock jetting from Kawwi is pretty lean for a boat out of the crate let alone a big bore set up.
Brian
keefer
T1
Tennessee
Tune with jets, the low end screw is for idle tuning only. The high end screw can be used to fine tune the main jet circuit for upper RPM mixture.
