- Idaho
Well I have been tuning my ski after the wetpipe install for about 1 month now and am determined to get it right myself. All manuals and articles have been read and understood for the most part. I feel that I am very close but want some insight to whether I am moving in the right direction or not. My problem now is the low speed circuit. I tune the low speed adjuster at idle to max out RPM then turn back 1/8 turn. Little smoke at idle and it is smooth. Then I gun it and it falls on its face (no blubbering, just sounds exhausted and will not recover). Now if I back out the low speed adjuster I can get the throttle responce good but it smokes like a pig at idle. My thoughts are telling me that I need to lower my pop off pressure for adjusting my low speed adjuster out is covering up the lean condition. Does this sound about right?
Ski is a 07 SXR with wetpipe and K&N filters. Low jet is 80 and high is 150.5. Still waiting on a popoff gauge but have a 2.0 N/S with a 95 gram spring. According to the mikuni chart, I have a popoff around 25psi.
