STOMPER
FIBERGLAS MULISHA
- BROOKLYN, NY
Can i use a spring with dual breather hose?My set up has no spring & i dont like it!Can some one post a pic of there set up with a spring.Thanks
I used it with an X-Metal stainless steel bracket and it worked well, I cannot be certain of the fitment with other brackets.Yamanube does the Kawi spring work sweet with the yamaha bracket ? Even the HD spring ?
OCD did you use an oem spring and did you have to cut down your spring to make it fitI used the RRP tensioner on both mine.
I can't remember exactly which method worked to install the spring but it was a combination of sliding the pivot bolt in from one end while using a long tapered center punch from the other end to keep things in place.
I also seem to recall it being easier to slide the pivot bolt through before you put the spring up on the RRP tensioner. Once the spring is in place, use a pair of pliers and a prybar to get the end of the spring up on the little platform.
It's not pretty in the end but it works.
