Needle seat
PNW
I recently put together a new 735 jetmaniac ported motor and picked up a blackjack 44mm carb to put on it. On the first ride out the plugs have been fouling horribly, so I bought a pop off tester and my pop off is reading about 12psi! What needle valve would you suggest for a 735 with a factory 4 dry pipe. Current jetting feels good once im on the throttle and it clears out but slow idle is terrible. Im thinking either a 1.5 or 1.8 needle and seat with either the dull or shiny springs... Any suggestions?
thanks
Mike
according to the chart, you seem to have a 2.5 n/s with 65g spring if your p/o is indeed 12 psi. I'd keep that n's- if not worn- and do your dull spring for 17 psi. This also might effect your low speed circuit favorably
Quinc
Buy a Superjet
California
PNW
sorry, I should have stated yes it is a 2.5ns but both the shinny silver and dull silver get me about 10-13 psi Pop off currently. When I spoke with Art at Jetworks he stated that if the motor is a "shaker" that I might need a stronger pop off to keep the carb from flooding. My motor is definitely a shaker so I'm hoping a stronger pop off can help cure the flooding problem. Everything I read says to go 25-35psi, is that still correct?
Thanks
Well roughly guessing, in that case you might even have a worn needle. Look at it closely and if needed use a magnifying glass: is there a groove worn into the viton tip? I would not go smaller than 2.0
JMew03
The call me Mew Mew
DFW,TX
Did you ask Jetmaniac? He sent me everything I needed for my 735 engine and it rips. Dont ask me what it is though. Lol
JetManiac
Stoked
Vendor Account
orlando
He can assist the op with getting the carbs set up for the engine. He knows his stuff.
He does, but Art knows the specifics of jetting blackjack carbs, which are modded and jet and tune differently than oem or std mikuni a/m carbs.
PNW
Thanks for the info guys! I had called Art already once and didn't want to take up anymore of his time. His recommendation was a 2.5 needle with a 95 or 115 gram spring. He said something about the motor being a shaker that I really didn't understand at the time because I had never changed needle or springs in carbs. I think he said I may need to go lower on the needle valve to keep it sealed if the motor runs a bit rough. I've seen a bunch of posts in my research today that says a smaller needle valve will hold pressure better when the motor shakes.
The whole "shiny, dull,platinum, silver" thing really threw me off... I found a post showing a picture of the different springs and realized that what I thought was the "shiny" 65g silver spring was really the platinum 115 gram spring. So i popped it in an was able to get about 19 psi pop off. Took it out this afternoon and it definitely ran better than before but still seems to be struggling at idle for any extended periods of time so I just ordered a 2.0 needle valve and will play with getting the pop off up and see how it responds.
Thanks for the replys! I've learned a lot about carb tuning over the past week!
