Needle valve idenification help!
Just got a set of buckshot 44's for my X2. The needle a seat have no identification whatsoever on them, o-ring type. Just trying to figure out where to start with. Not really sure what the guy was running. Thanks.
-Will
#ZERO
Beach Bum
Florida - U.S.A.
Where the fuel enters the seat there should be some number stamp on the bottom like 1.5, 2.0, 2.3, 2.5 etc.
If the number are not there you can always measure the hole diameter with some veneer calipers or check the pop off pressure.
Yeah there is nothing stamped in it.. It looks a little different than others I've seen. It a push in type, with an oring. I think I'll check the pop-off in a few, that should pin it down for me.
#ZERO
Beach Bum
Florida - U.S.A.
Get yourself one of these; they work great for reading jets and seats numbers.
http://cgi.ebay.com/ILLUMINATED-10X...ryZ34084QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
