- Plano, TX
I'm getting ready to add dual 46mm SBNs to my SXi-PRO and I had a question regarding the lines.
Since both carbs will have their own fuel pump, will I need to drill another pulse line into the case, or can I run both fuel pumps off one pulse line? I guess the other option would be to get an external fuel pump and buy two block off plates for the carbs, correct?
Anyone experimented and found out which way was best?
