Is this the pipe that will be offered by blowsion? is the manifold included?
The manifold will not be available till next yr.
and the Blowsion pipe will be slightly different as it needs to fit all freeride boats.
I am only going to build about 10 of these this yr just to keep development going and improve on the design.
600.00 for chamber in mild steel. Not going to build any stainless till next yr when manifold is available.
The mod pipe is by far best wet pipe we have built bar none. 11hp gains over the TNT super stock chamber and capable of 8400rpm with right setup.
7850-8300 is targeted rpm for this pipe. It does require some tuning to get the power to be smooth.
Requires at least 28 deg timing base. I like 30 deg.
Spec class has slightly longer pipe so you get good hit without added timing but spec pipe signs off 8,000 max
