jetski9010
Team RTYD
- Lancaster PA
I have seen stuff from a while back saying Jetinetics was working on a newer total loss sytem. Anyone know any recent info if they are still working on it or is it still just talk right now?
What "bad" have you read about the ATP?
I have seen the ATP ones and have read some good and bad about them. Didnt research that system very much yet so dont really know everything about it. I am not ready to get a total loss setup right now anyway so maybe by the time I am ready jetinetics will have a system out.
maybe I am wrong I thought I had seen something somewhere saying the ATP system was good but something (coil or something I cant remember) held it back from performing as good as the MSD does. I just looked again now and cant find it some maybe I was wrong.
so it has 1/2 the dwell time of the MSD multichannel system.
Could you explain that? :dunno:
Sprry, dwell time can refer to several things. In this case I meant the time to charge the ignition coil.
The ATP system uses one two pole coil. In one revolution of the engine the same coil gets fired two times.
The Multichannel MSD system has two individual coils. Each coil fires only once every revolution so there is twice as much time to charge the coil.
Aaron
Aaron
More time to charge the coil = more engery in the coil when it goes off = hotter spark.
isnt the coil always charged?? i thought the transister flicks it off?
the only real performance advantage i can see from a dual channel is that you can retard or advance different cylinders
think you are trying to mix the way stock systems and Total loss systems work here.On a stock AC system the coil is not charged all the time since AC voltage from the stator charges the coil.On a Total loss system the coil would be charged waiting on a signal to fire it,that is why on the older systems there had to be a cutoff switch or you would fry the coils in short order when the boat was not running.
