300/440/550 New stator and flywheel and still no spark
A month ago I had a bolt come out of my charge coil and destroy my stator and flywheel. So I installed the new parts today and I don't have spark. The ground wire from my old stator to the e-box was melted when I took everything apart so I replaced that. Could my coil have been fried when my stator was destroyed? What else should I take a look at? Thanks
NJ
check simple stuff first , take off spark plug boots and cut back wires 1 inch and re install nice and tight . I think there is a way to check coils but im not sure
The ground wire probably melted because the tiny ground wire that goes from the battery to the ebox was missing or broken. Make sure you have everything hooked up correctly, you may have simply crossed a wire.
RKO Motorsports
Formerly 97gsxguy
SE MI
Double check all connetion/grounds. Like stated above, cut back the plug wires (make sure you don't cut off to much to the point where the wires no longer reach). It is possible you damaged the coil. If you end up needing one PM me I have some.
